History and summary of what I'd like to accomplish:
On my truck, I specifically purchased the dual 220amp alternators because I had a crazy idea of being able to run an A/C in a yet to be purchased slide-in while going down the road. Over the years I've downsized my rigs from a big fiver, to a toy hauler, to not a slide-in with just a trailer for the toys. Main purpose is to get in and out of more remote locations. I've recently moved from Phoenix to Georgia, but drive back every few months towing my off-road buggy, and at times add a couple quads to that trailer. Would be nice to keep the interior of the slide-in cool for the dog, and for the quick side of the road lunches, without using a genset. Over the years I've always had built in gensets, with built in gas tanks, and have always kept my rig cool no matter where I was driving. With a slide-in, the built in gensets are propane, and obviously I don't want to blow through propane whereas previously I didn't care as I typically could run the generator for 75+ hours on my built in fuel tank.
My thought process so far:
Alternators are rated at a certain RPM higher than idle. In addition, I'm sure they're tested at 80 degrees in a lab somewhere, where in my case they'll be running in a much hotter engine compartment while driving potentially in 115 degree ambient air, on top of 160 degree black top, while in an even hotter engine compartment. Although my alternators are rated for a combined 440amps according to the propaganda, let's say they're only good for 50% of that taking the variables into account and at idle. This brings us back down to 220amp available anytime the engine is running. Does this sound like a fair assessment?
I'm not sure what the startup and running amps are for say a 11k BTU air conditioner, but I do know I've read countless times that people are running them on Honda EU2000i generators. Since I don't know what A/C I'll end up with (since I haven't decided on my slide-in yet), I'll just pull the specs of this genset and see what I'd have to "duplicate" in the power generation department. According to the specs, this generator is rated at a startup of 2000 watts (16.7 amp), and 1600 watts (13.3 amps) continuous. If you take the 12v amperage of 220amps from the alternator, that translates into 22 amps (inverting 12v to 120v) at 120v. I do know inverters aren't 100% efficient, but it looks like the continuous 13 amps should be able to easily be provided by the alternators, even at idle. I know there are plenty of 2000 and even 3000 or more inverters, and assume finding one that can run the A/C won't be an issue, though I'm not sure how hard it is on them. Hope some can chime in here...
Batteries/Inverter:
Honestly it's been a couple years since I've evaluated golf cart batteries and tried to understand amp hours and how it relates to what I'm trying to accomplish. Knowing space is tight, could batteries 2 golf cart batteries handle the load I'm talking, feeding a 2000 or 3000 watt inverter, providing 13amps of continuous power and any inefficiency overhead of the inverter? If so, does anyone have a frame of reference of how long? Are we talking 15 minutes, 30 minutes, 2 hours? I ask this question because although I plan to run the A/C going down the road there are obviously times when I want to run into Denny's for a Super Bird and a coke, and may or may not turn the truck off. I'd like to figure such stops into my realistic expectation.
Charging the coach batteries:
I think it goes without saying I'm not expecting the charge wire in the 7-way plug to be able to keep the coach batteries charged at the amperage draw I'm talking about. I had pictured running some appropriate gauge wire from the engine compartment along the frame and up into the slide-in, using connectors similar to the ones used for receiver mounted winches. This would obviously be about a 25' run. Would I literally run my coach batteries in parallel to my truck batteries to get all this amperage? Or is there some sort of charge controller needed in order to make this happen? I'm completely ignorant here on how this would work.
Hopefully this isn't too wordy, curious everyone's thoughts.
Mike
Batteries/Inverter:
Mike
