I know that's what you have. .
An unrestricted 1/4" line is TOO much flow for a bypass filter. Like I said it's 6300% more area than the standard bypass restrictor orifice. With the design of the older BMK-15 and a full flow filter you literally have a 1/4" line diverting oil from your motor all the time, that's a lot of oil to not go thru the motor, and very little actually going to the bypass.
Did you add an oil pressure gauge to know you still have good pressure? The OEM gauge is fake.
That link was about the Fleetguard Venturi filter, which is not a traditional bypass. Cummins allows 1 GPM for bypass on the ISB, I can guarantee you are far exceeding that.
This Cummins bulletin states that bypass filters should use about 10% of the oil, which the 1/32" orifice provides.
Cummins Engine Oil Recommendations
