as the dmf fails it puts side stress on the g56 and ruins the g56 housing if you do not catch it in time. efi live is the best choice by far smarty jr next. we tow extremely heavy in the mountains at 425 hp and 900+ ft lbs torque. oil type and quantity is critical in the g56. I do not see where you live but here go's if you live where id does not get into the teens very often you can use the straight 50 wt listed below, you can get the delvac equal at ww granger, the delo at chevron distributor Castrol at o'rileys ( order) the numbers are o'riley and amsoil part #'s if you live in a colder area you will need to blend a 50-50 mix of royal purple syncromax or amsoil 5w-30 manual transmission fluid, I see where the new bottles do not list 5-30 on it. fill the transmission two quarts over full. and use the straight 50 in the transfer case. we also think the fluidamper or 6.7 is a good idea.
Delo Synthetic Transmission Fluid SAE 50 delivers exceptional all-climate, year-round performance in heavy duty truck transmissions. A unique additive package can protect gears without using the “active sulfur” agents commonly found in automotive axle oils. This results in little to no corrosion and long life for copper-containing parts, such as oil coolers, bushings, and thrust washers. Good pumpability in extreme hot or cold temperatures promotes smooth shifting and efficient power transfer. It is specifically formulated to meet the latest extended drain requirements for Eaton transmissions, with drain intervals of up to 500,000 miles.
Synchromax is recommended for manual transmissions
that specify an automatic transmission fluid or motor oil.
It is also ideal for transfer cases and 2-cycle motorcycle
gear boxes.
Synchromax is formulated with Royal Purple’s synthetic,
proprietary Synerlec additive technology, offering
improved shift quality over a wide temperature range and
reduced gear noise.
Synchromax is fully compatible with all types of friction
materials and offers excellent corrosion and oxidation
protection without affecting the soft metals commonly
found in manual transmission synchronizers.
Performance Advantages
• Greater wear protection
• Smoother shifts
• Excellent rust / corrosion protection
• Reduces friction for more power
• Lowers operating temperatures
Castrol 50 wt is syngear CD50 o’rileys p/n syn 50-5
Amsoil FT F05-EA
