RJOL said:This is a relatively easy mod that some have done on this forum. All you need to do is put two probes in (one pre and one post) and run the probe wire up to a SPDT (single pole double throw) switch. You can then just switch between the two whenever you want...![]()
GWBourne said:im not so sure this is a great idea. the wires are alumel and chromel (sp?) and the conductivity is sensative... id stick with two gauges and do it that way.
NJT said:Did someone say they saw a dual pyro single gauge setup?
