I started on my guage install and had a couple of questions and observations.
I thought that between rain showers today I'd get a few minutes to atleast plumb the boost line. I thought the guage was fully mechanical, needing only the vaccume line for a boost reading, wrong. The guage needs 12 or 24 volt power so it took me longer than I expected.
Though the directions from Geno's is very helpful I thought maybe they could expand a little more, like where to get switched acc power for the guage. I was lucky and found a relay used in my alarm that I tapped into with no ill effects so far.
At first I was scratching my thinking why don't I have boost pressure, I hear the turbo? Obviously, I'm a total newb to the diesel.
So I get the 12 volt supply, light power and grounds connected along with the boost line, wired with jump wires first to make sure everything was right. Jump in the truck for a test drive, I drove a few miles waiting for the engine to warm up, watching the boost readings go as high as 20 psi, Sunday driving.
Once it was warmed up I gave the skinny a small stab and watched the boost climb to approx 28-30 psi and then drop to zero while still accelerating. The hose popped off the barb. Fixed it and it did it again.
I got home and tied a small zip-tie really tight around it and pulled up on the hose, it's going nowhere now and hopefully the guage side doesn't do the same.
So here's three questions I have;
1. ) Is there a nice place to grab keyed 12 volts under the dash?
I'm afraid of tapping a wire the might be resistance sensitive.
2. ) Did other Westach owners do similar to fix the popping hose?
I've never seen a hose clamp for 1/4" hose. I do have a few expanding hose clamps but the smallest was 5/16".
Next I need to conquer my fears and drill/tap the manifold for the pyro. I'm not too concerned about the optimum location for the pyro so I'll probably drill just above the turbo.
3. ) Is the turbo easy to move out of the way?
With the turbo disconnected from only the manifold so I can tape over the turbo inlet I need to sepperate them enough to blow the chips from the turbo.
Will the turbo assembly flex around a little.
Thanks, Doug
Thanks, Doug
