dually air pressure
DPF delete and smoking
Should We Install a Fuel Pressure Gauge?
Yes, a long stem double sided air chuck. I have one with a gauge built in. I also carry a double sided truckers long stem gauge in my truck.
What u wanna do is go to a truck tireshop and tell them you want the long metal stems and Gators put on the ends too. It will make it much easier to air your tires up and down.
The best way is to use an "equalizer" which connects both tires to a common stem. They have check valves to keep the inflated tire from going down if you puncture the other one.
