Dually rear brakes
DC does it again....
Recommended 2" spacer?
I checked my rear brakes and found one inner pad was down to metal (not good) so I want to have the rotors turned. How do I get the rotor off it looks like the bearing and rotor is one assembly, It can't be that hard
04. 5 SLT Dually Quad cab,325,3. 73,Auto,Banks Sixgun,Exhaust,AFE Intake,B&W turnover ball,Rino liner
My 04 Dually went 160K before its first brake job... you need to pull the calipers on both back wheels and look for damage to the boots... . we found that the boots were damaged and the piston would not retract back correctly allowing one pad to wear excessively... ... . Too much dirt behind the boots... . we had to put new kits in the calipers... and because of how rough the pistons were. . we replaced them as well...
In most cases... . a large brake lathe needs the hub attached to the rotor to turn it..... We have such a lath so we just pulled the complete back hub and rotor... chucked it up in the lathe and turned the rotor. .
You pull the axle from the housing... . remove the keeper that holds the nut tight and back off the nut... .
Inspect the bearings and grease them before you put it together... and than check the oil in the rear end.....
Thanks, I must have something wrong with my caliper on the one side because I have only 51,000 on mine. No exhaust brake, I know that helps a ton.
