I recently became the owner of a 98. 5 Ram 3500, my first Dually ever. I have a silly question
I was attempting to check the air pressure in the rear tires last night and discovered that the inner tire valve is very hard to get to. I wasn't able to get my hand between the tires to even unscrew the valve cap. I think I can probably get to it through the opening of the outer wheel if I use a long needle nose pliers. Is there some other trick to doing this, other than contracting with my daughter with teenie hands that fit between the tires? I was feeling a slight pull to the left when driving on the highway and suspected low pressure. The left outer tire was at 42 psi and the right outer tire was at 60 psi. Might this be enough to explain the pull?
