I bent/creased my nylon tube. since I was half installed I ran it to the boost bolt. No boost shows. if I disconnect it from the gauge you can hear/feel the air.
Is this what I assume? cracked line? I didn't think I needed plumbers tape on the crush fitting ends, I should be good with out it there correct?
The crushed end is in the engine bay, so under any real loads you naturally can't hear it.
