Dumb question, but where to buy tubing/steel?
What is...?
If you need a laugh try this.
Howdy!
Call me a dummy but, I'm wondering where I can buy some steel tubing and just a couple small plates of steel.
I'm wanting to make a test pipe to, "test," my catalyst (see my post about Catalyst Problem? I need help!).
All I'll need is about an 18" section of pipe and 2 small plates to use as flanges. I'll measure the pipe length, diameter, and thickness and flange size & thickness tonight when I get home.
All I need to know is where to buy these things. Thanks.
- JyRO
Y2K 2500 Cummins ETC/DEE, SLT+, 4X4, Quad, LB, Intense Blue Sport, 3. 54 LSD, rear aux. springs (camper special), sliding rear window, all options except cab clearance lights including agate leather, totally stock engine, silencer ring removed, "stealth," mod to run fogs with high beam. (20. 8 mpg @ 70 mph) Since everybody else listed their toys, I will too.
2000 Toyota 4Runner SR5 4X4, 5-speed, 3. 4L V6 (25. 5 mpg @ 65 mph)
1995 Kawasaki ZX6-R, 97 H. P. @ Rr tire, 6-speed, . 6L I-4, 410 lbs. wet
- (60+ mpg @ 65 mph, but who can do that?) (For Sale)-[SOLD]
1990 Toyota Celica STX, FWD, 5-speed, 1. 6L I4 (36+ mpg @ 65 mph)
1983 Mazda RX-7 GSL Limited Edition RWD, 5-speed, 1. 1L Wankel (For sale)
No auto trannies in my home! Just say, "No!" to auto trannies.
Any salvage places around? Here all the salvage/scrap metal yards are full of what your looking for. Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, CTD 3500, Air brakes on truck & trailer. 202,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy. 211,000 miles
Just bought another 92 D-350 215 P-Pump motor and NV 4500 180,000 miles 24 lbs boost all stock For now
A muffler shop will probably make up what you need, just don't tell them what you want it for. The ends of the pipe will need to be flared to hold the flanges on anyways, something you will need a muffler shop for.
Down here we have places called General Steel and Chatham Steel. They will sell anything from plain old rusty plates, I beams, tubes etc through the best stailess.
Howdy!
Just to let you guys know, I stopped by Advance Auto Parts to see if they had any small straight sections of exhaust pipe. The guy behind the counter found the smallest piece they had. My existing pipe before and after the catalyst is 1. 67" O. D. and about 13" from outside edge of flange to outside edge of flange.
The piece of pipe I bought was only slightly larger in diameter and about 18" long. I bought it for $5. 69 + tax = $6. 03.
Once I have removed the old catalyst I'm going to re-use the old flanges (catalyst side) for obvious reasons (existing mount holes and exhaust hole!) and cut this $6 piece of pipe to fit. I'll have to buy new bolts, I'm going to TRY to salvage the original gaskets (I don't give a cr@p about a small exhaust leak on an 11 year old car (as long as its really small). Total cost, less than $10.
The Toyota dealer wants $572 for a catalyst plus at least $100 labor. And then I'll have to fix the root problem if the catalyst is not it.
I've got some preliminary information about how to check the codes on this vehicle. I could probably get the codes now. The problem is, I won't know the meaning of the codes. But I figure I could call the dealer and ask them what the codes mean and go from there.
Any suggestions, comments, questions, or concerns are welcome, and thanks.
- JyRO
