Well in my ongoing trial to solve a grinding noins with my dyna Lock hubs on my 2003 2500 the latest "Fix" was that dyna trac shipped me two bushings which were omitted from the first Kit. Well the install went fine and this corrected the pass. side but the drivers side still makes the noise. My call to Robert at Dyna Trac has not been returned yet.
I have a favor to ask of all that have installed these hubs. Will you please go out and lock (engage) the hubs and drive the truck in 2 TWO wheel drive and see if you hear any grinding noise.
I only want to do this (engage the hubs in 2 wheel) to rotate the front dif and circulate the gear oil from time to time. I know I can accomplish the same thing by shifting the transfer to 4 high with the hubs unlocked.
My concern is if the hubs wont fully engage and hold the axle in two wheel then will they do it (engage) in four wheel.
Again, the only time I hear the oinse is with the hubs locked and the transfer in 2 wheel drive. If the transfer is engaged the noise goes away.
The Crown cams were getting chewed up on the ID and Robert said he was aware of that issue and sent me new Crown cams.
Monday I plan to take the drivers side hub down and check things out.
Again please let me know of any of you have the noise.
Thank you
Thank you
