I cannot run any of the tq settings on my TST, while I have Smarty software loaded, it pops. And if I turn the power past 3 on the TST while stacked with Smarty, I lose power.
How did you manage to get 06 headlights on your 03? And why?:-laf You did not change your "scalloped" filler piece between your headlights and bumper.
Jess
This is what I ran to get the popping.
Smarty Level 9 REVO (Torque Management = Wild, Injection Timing = for Aftermarket Injectors, Rail Pressure = Wild)
PowerMax CR (Power = 5, Torque = 5, and Rail Pressure = 3)
The settings above equated to about 430hp.
I then changed the PowerMax CR as noted below.
554 hp and 1021 tq = PowerMax CR (Power = 4, Torque = 2, and Rail Pressure = 2)
544 hp and 1235 tq = PowerMax CR (Power = 3, Torque = 3, and Rail Pressure = 3)
This is with the timing advance turned off on the TST.
YouTube - 2009 07 16 09 56 06
Those are 07 headlamps (bigger reflector then the 06) mounted to 06 fenders. The bumper is off an 05 due to a run in with a Mercedes. I am saving money for a baja type bumper from Carli Suspension. Oh and the reason I went with the 07 headlamps is because I have 55w HID's behind them and I have no need for anymore light.
