Engine/Transmission (1998.5 - 2002) Dyno results not to good
Engine/Transmission (1998.5 - 2002) Injector inspection question
2nd Gen Non-Engine/Transmission need an alternator w/ internal regulator
yeah those numbers aren't right. Maybe the comp not working correctly. With my setup w/o injectors i made 370 and 792 on level 5x4. Hard to believe you're only at 423. Also mine is not the drag comp. My gears are 4:10's and tire size 305's. Not quite sure what's wrong, just thought I would share with you. I'm sure others will have ideas. Good luck
I have the Catcher made to run with the drag comp. Also a while back I took out an easy edge and went to the drag comp so I know it was working.
