Dyno Shops - Diesel?
0-60 time of a stock truck
Low Sulpher Fuel
I have the impression that putting my truck on a dyno at a shop that is not familiar with running diesel trucks will not yeild accurrate results. Is this reasonable? Perhaps the difference is between a Mustang where I understand there is a lot more operator input as opposed to a DynoJet. Also, is there a difference in how the test is run in terms of driving the vehicle on the rollers and/or how the test is administered?
Your right. With a Mustang its more operator.
With a Jet having a good operator is nice (Dunbar), but the dyno itself if more user friendly than the Mustang unit (at least in my experience).
Less variation with a Jet also.
what kind of dyno was your last run on?
I vote for David Dunbar as well... . He has dynoed everything from 1000 hp mud racers to mopeds and his team is top notch especially when it comes to safety.
jdakin said:
BILL WANTS 525 Oo. :-laf :D
YEPPERS! Damn Goals... . :-laf :-laf
My last run was on a DynoJet at Kauffmans, a very reputable shop. So I don't have any issues with that event. But I was expecting more in the 525 range so "only" hitting 501 (on the 3rd run) was a bit dissappointing. I know... I know... :{ :{
I recently learned that I did not have the wastegate hooked up (duh). Speculation is that was robbing me of at least 10-15hp, hopefully more (sounds weird).
I agree Dave is the man, but I will have to wait at least until spring to attend an event where I am 100% confident in the equipment and operators. However I hear about other shops located within a reasonable distance that I can run on, and/or are having a diesel truck event. But still, I have been disqualifing them unless I know that they have strong experience with our trucks.
So, before I go blow the $$ and time, I am curious how reliable to the results will be from a shop that is not necessarily experienced with running our type trucks.
Just thought I would check back... .
Once again, I am not necessarily comparing machines or my numbers. Just trying to get a feel for dyno shops in general. There are a lot more around that "typically" run gas cars, however many of these will run diesel trucks. Common sense tells me to go to a shop or event that specializes in running our trucks. I am just trying to get a feel for what other people think about running at a shop with limited or no diesel truck experience.
TIA,
Bill
Bill,
Find a shop that has a dynojet 248c or 248x. Ask them if you can operate (drive) your truck while you run it, then give me a call and I will fill you in. There is really no big trick to it but rather its more important to understand what to do.
Doug
Bill if you dyno soon let us know!! :D
Well from the driver seat :-laf it feels a good 510 rwhp, now from the passenger seat with crazy bill driving its a good 535 rwhp :p
@ a certain event on a mustang dyno my truck hit 297 rwhp, then at another dyno same place just a few months apart and a few more miles on the rig it dyno'd in the ball park of 30-40 hp less (on the second run) Im sure the difference in outside temps made a factor but thats quite the drop isnt it? :confused:
Bill- didnt you have the same situation? or was it you put down more hp with the comp off than with it on?
Ian
Well from the driver seat it feels a good 510 rwhp, now from the passenger seat with crazy bill driving its a good 535 rwhp
Well, I suppose once you've blown one up you have less fear. :-laf More respect, but still less fear.
It pulled 460hp in mid-Aug '03 on a Mustang at a reputable event with their operator driving, ... too high by an estimated 35-40hp. Next was 343hp in mid-May '05 (very different weather) on a different Mustang at a shop without diesel experience, with me driving. However in all fairness at the May run I was putting out the fire by over-fueling on the low end. The VP key was jacked and I was experimenting with a part combination that did not seem to play well together. I did hit a higher number on 3x3 than I did on 5x5. But an 80hp loss seems extreme as well. Most recently 498, 499, 501 in mid-Oct at a reputable event on a DynoJet with their operator driving. This time the wastegate was disconnected thus hampering my numbers. One of these times I will get it right :eek: :eek: :D
