I finally had my truck dynod on Friday. Did a couple of runs with just #2 (blended winter fuel) and a couple of runs with the water/meth (wiper fluid) injection going. Dyno was a DynoJet with heavy (7400lb I think) rollers at Dynomite Diesel Performance in Monroe Wa.
Here’s the results.
Straight #2
Actual (uncorrected) = 425hp/895ft-lbs
SAE (corrected) = 413hp/871ft-lbs
With water/meth (-40F wiper fluid = 50/50)
Actual (uncorrected) = 459hp/945ft-lbs
SAE (corrected) = 447hp/920ft-lbs
I have copies of the charts on my computer, just need to figure out how to get em up here.
Conclusion
Water Meth injection made a difference of about 30hp/50ft-lbs but with lower EGT’s
Interesting Note:
When running with the water meth. injection, as soon as it hit 3kRPM it sounded like somebody threw a handful of fire crackers in my exhaust pipe, the smoke cleared up instantly and the motor started sputtering (combustion quench). When I first installed the system I experienced combustion quenching at lower RPMs when not running enough fuel with the water/H2O, basically just not enough pedal in it. This time it was from the governor cutting the fuel at WOT. I generally shift or let off before it starts de-fueling on it’s own but during the dyno run they run it through to the end. When it happened I just about **** myself, It’s a little spooky when your trucks screaming away then starts it’s own internal firworks show (can’t be good for the turbo). I made sure Mike understood he needed to keep er down once the pump was going (not an issue on a Dyno run) but never thought about when it started de-fueling at the top end. Probably also had something to do with the lower engine load on the Dyno vs load on the road.
All is well.
Mike
Here’s the results.
Straight #2
Conclusion
Interesting Note:
All is well.
Mike
