Dynomite Diesel 90hp injectors installed!
D.I.Y. ATF Change question...
Factory Air Filter Feedback
Yesterday I got around to installing my Dynomite Diesel 90hp injectors.
My thoughts so far with about 20 or 30 miles on them is that they are no less than GREAT!!
So far the truck smokes less has about the same amount or more power as with the Bullydog on the 90hp setting.
Truck sounds better, Idles smoother, and makes less noise under throttle (I dont have to use the electronics now running around town!)
Thanks DDP!!
Everyone needs INJECTORS!! :D
curious, how do I find out more about these injectors you got, ( price and where to purchase) and do they work ok with the stock turbo and upgrades as on my signature?
What's the scoop on injectors? Pros: More fuel,... Cons: higher egt's??? What else? 90hp injectors sould good to me, but what else do you need with them? Can you use them in lieu of a box on an otherwise stock truck?
I'm considering a set of these on my truck but don't want to hurt anything. Especially my clutch <grin>. Right now I'm just running what's in my sig, Quad Xzill (running it on the 100hp setting all the time), AFE II, 5" straight exhaust, stock turbo. Any thoughts on cons of adding these injectors to my current setup? Thanks, Wolfman :cool:
