I want an e-brake in The Beast... we tow horses, and SW Pennsylvania can be mighty hilly.
So, I've read umpteen old threads on the topic of e-brakes on Rams with auto trans, but I'm no more informed than I was when I started. Opinions seem to range from "no problem" to "you'll need 60# valve springs" to "you'll need a new TC and VB," to "you need a TC lockup switch, to any/all combinations of the above, plus people disagreeing with all the above.
With some regret, I'm going to open the topic up for discussion again, to see if we can achieve something like a consensus. Given my vehicle's characteristics (see sig, and transmission/TC/VB are stock and work well; transmission cooler lines have just been replaced with the new flared fittings, no more quick-disconnects Oo. ) what do y'all think... can I get away with installing an e-brake (I'm looking at US Gear's) without trashing my transmission? I should probably add that unlike out West, we don't have miles-long grades around here... just hills. If I was conservative and just used it when really needed, on relatively short grades, might it be OK?
