An automatic needs 2 things during engine breaking, a lockup on the TC clutch and enhanced pressure on the clutch packs. Torque converter rotors & stators are meant to apply power from the engine to transmission,. Low throttle position will drop clutch pack levels to idle or nearly nonexistant levels on a stock trany. Changing to 60# springs does give you greater engine braking. Running the backpressure too high will float springs, in any engine. <small>Ever read the fine print on Pacbrake? The highest engine braking is from a 12v with 60# springs. </font>
Bill, You can slap me if anything is offbase.
I've been debating the engine brake myself. Not enough hills around here to consider. The biggest problem is idiots that ignore stop/yield signs.
Cheers;
John
97, 2500, auto
<font size=1> I am not an employee of nor affiliated with DTT, BD, or Pacbrake. </font>
