E- brake noise
EZ box.
in line auto/trans filter
I just installed the e brake on the truck. What kind of noise should you hear when the brake activates. I hear a loud hiss that sounds kind of like a big vaccum leak. Being this is my first brake I don't know whether I have a leak or if this is normal. The brake does work, but it was dark when I finished so I haven't had the oppurtunity to check for leaks.
Thanks for your help
2001 Quad Cab 4x4 ETH
I assume that you are listening to the truck as it idles with the brake on. The hiss is normal for the E-brake. Let the truck idle with the brake turned off and the hiss should stop.
If you have created an exhaust leak it should be fairly easy to locate - one end of the elbow or the other.
Yeah, mine makes that noise whenever it is engaged. That excess pressure build up has to go somewhere I geuss. When I disengage mine it sounds like like air brake pressure release.
ed
  • '93 250 LE 4x4 5spd 4:10 Pwr win/loc/mir,cruise,dual 5" chrome stacks,12cm² turbo,PW injectors,K&N,pyro/boost,US Gear E-Brake,Fuller Roadranger shifter, diamond plate tool box, CB, 16x10" AR rims, 285/75/16 Bf goodrich, . "wirenut_21529" on Yahoo Messenger
  • '96 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
[This message has been edited by Wirenut (edited 10-21-2000). ]
Yes it is normal, it is the exhaust passing through the hole in the butterfly. Had someone the other day ask if I had air brakes #ad
Mike Clay
2001 HO,6 speed QC,2500,4x4Dark Garnet Red,ISSPRO E&B gauges on A Pillar, Rhino Nerf Steps Lit, NW Custom rocker panels, Jacobs E-brake, all options except leather, Reese 20k hitch. Towing a 30' Gulf Stream Sea Hawk 5th Wheel triple slide. The Mule
Thanks everyone for your input. Now maybe the wife will stop thinking that I screwed something up after I show her this, but I doubt it. #ad
[This message has been edited by 1BIG44 (edited 10-21-2000). ]
This site is great. I also have the hissing sound and was getting ready to crawl under truck and see what I had created or did wrong. Talk about relief. Thanks much #ad
MikeR... you just think its the straight-piped exhaust brake noise... really they are freaked from watching you go sideways down the four lane!
