Check this web-site out. www.tirerack.com they have alot on info on tires. coobieNLofton said:Does anyone make this size in an all terrain tire? Will these work on a 04 dually with the 2" spacers and stock wheels ? Don't really want the BF Goodrich brand, hopefully i do have a choice.
Spooled-up said:Toyo makes a 285/70R17 Open Country A/T in load range E. RANKRAM has a set on his SRW. He swears they are load range E with a load rating over 3700 lbs marked right on the sidewall. The Toyo Website has them as a load rating of 2755 lbs with no mention of the load range. I'm not impressed with the accuracy of the tire websites I've been on.
RankRam said:
Bertram65 said:Where did you get them?, every Toyo dealer I have called says they do not exist, that is the size and load range I want.
