Eagle alloy 19.5 aluminum
Front U-Joints and Ball Joints
Timbrens question
I've seen them on a couple trucks, very nice looking. You should be able to get the inner steel wheel from the same place you get the Eagle wheel. I went with the Vision 181 Heavy Haulers, got the inner steelies when I got the alums. Mine are direct bolt on also. I got my wheels from www.duallywheels4u.com/ they have 19. 5 steelies.
CD
CD
The only steel wheels I can get in the bolt pattern have to come from Rickson or Stockton Wheel. I get the Eagles from American Eagle..... :eek: They don't reccomend any steel wheel to go with their aluminums... or at least my account manager doesn't know of it... . not sure he's a full 60watts or not... . :cool:
Thanks for the response!! Did your wheels have any brand stampings on them... . Accu-ride, Fumagali, etc. ?
I think I have the same wheels you are looking at on my truck just search in the photo gallery "megacab longbed". I bought mine on ebay for 1450 with steel inside wheels and then 1200 for a set of cheap chinese tires(bad ideal). I have almost 100k with no problems. I wouldn't worry about the steel to alumiun. The Eagles are not hub centering the lugnuts have a long shoulder that goes into each bolt hole to center the wheel. Again no ploblems so far but would have preferred the hub centering. I think the Rickersons are hub center but they are more money. A cheaper tire that is shaved and balanced will run over 100k still running on my first set. They just aint speed rated for 120mph on the speedo!! Most truck tires are only speeed rated for 75mph and you will lose some ride quality.
