Fabricate jack screw brackets using a pipe hangar clamp, 3 each 1/2 inch nuts welded to pipe hangar housing 120 degrees apart, 3 short lengths of all-thread. Set weld nuts such that all-thread jack screws lay parallel to exhaust pipe and would push apart a coupling if similar clamp/backstop were bolted to other side of connection. No torching required to break loose, just load the jack screws fairly good, rap joint firmly with hammer and keep adding jack screw to push pipes apart. Also weld a nut to tail end of all-thread jack screw making it easier to use. Exhaust pipes can also just as easily be drawn together with same brackets and bit different ear configuration.
