The easy fuel filter changes of the 3rd gen trucks are no more. The new one on the 6. 7 engine is in a canister like the older model trucks. After looking at it for a while I went to the dealer and looked on their computer at the way they say to change it. Ready for this? Take the left wheel off and the inter fender out, drain the fuel, disconnect the wires at the bottom of the canister, I guess they are for water in fuel or something, take a filter wrench and remove the canister. That wouldn't be to bad, it could be done from the bottom if you had 4 ft arms, but there is a screen than has to be removed and cleaned that is in the "head", the part that the canister is screwed into. I don't see how that can be done from either the top or bottom. Probably through the wheel well would be the easiest, if not the quickest.
I believe Prime-Loc had a filter relocation kit for the mid 90's model trucks, so I'm sure someone will come up with a way to relocate the fuel filters on these trucks, but until then, it will not be nearly as easy to change the fuel filters as it was. Oh well, what is it, one step forward, two steps backwards.
