2nd Gen Non-Engine/Transmission ECM plugs
2nd Gen Non-Engine/Transmission Tach signal wires into the cluster
Engine/Transmission (1998.5 - 2002) Weird starting
Anyone know were I can get the three "prong" flat ECM connectors, so I can make a pig tail to run an EZ and my Quick Check at the same time.
I would need 2 female and 1 male.
I should be as simple as running the same colored wires together, right?
Thanks
J-
ps I know Edge will make one but they are dragging their feet on getting back to me so you are about to lose me.
I think they are just weatherpack connectors any napa should carry them, also I posted a thread needing the color codes before someone shopped their harness can you tell me when the qc is plugged in what color wires go to what?
wiring
Mcrossley,
I found your old thread and you wanted to know about the dark and light blue wires.
So I went out to the truck (see sig) and checked. Quess what? I have yellow wires were u have blue. . Go figure, must be a DC wiring job. But anyways this is what I found on my truck.
QC connector wires are labeled A B C and they as follows:
A- WHite
B- Black
C- Also black but with a noticeble dull finish.
ECM wires are as follows ( couldnt see the letters)
outside- Black w/ white stripe.
inside- Yellow w/ black stripe.
outside-solid yellow.
They match up like this when pluged in (QC wires are first)
White plugs to Yellow.
Black plugs to Yellow w/blk stripe.
Dull black plugs to Black w/ white stripe.
Thats best I could tell through the undercoat over spray.
Hopefully this helps?
J-
