2001 2500 4x4 ETH/DEE ("H.O", 6spd)...
Pretty sure I have a dead ECM:
I'm currently looking at "Nationwide Parts Distributors" http://www.npddiesel.com/cummins-1-plugs-ecms . Any experience (good or bad) with them?
- Starts and (seems to) idle fine.
- When I actually press the throttle and hold it in one position, it acts as if the pedal is in random positions (engine RPMs go from idle to "racing" and everything in between).
- Cruise control indicator in instrument cluster randomly turns on, as if I'd hit the on/off button on the steering wheel (I haven't touched it).
- OBD-II intermittent connection - 3 different devices (Smarty, Scan Gauge II, Actron)
- P0237 - MAP sensor voltage too low
- P0122 - APPS signal voltage too low
- P0123 - APPS signal voltage too high
- P0117 - ECT sensor voltage too low
- P0112 - Intake Air Temp Sensor voltage low
- I also seem to recall P0341 (Camshaft position sensor signal)
- And, the big one: P0606 - ECM failure
