ECM....yes again!
lift pump opinions
gauges
I have been trying to read the messages
being transmitted out of the CANBus plug on a 2000 Dodge. I have a
prototype board consisting of a Microchip PIC, a MCP2510, and a PCA
82C251. I believe that I have set all of the parameters correctly
for the 2510, but when I set it to listen for all messages I receive
only one message repeatedly with an ID that is NOT defined in the
1939 standard (HS-1939). Is this port really using 1939? Has anyone
successfully received valid J1939 messages from this port? I only
want to read some basic parameters that should be broadcast
periodically from the ECM (throttle position, engine RPM, etc. ) so I
do not believe that I need to transmit to the bus (but I could be
wrong). Any help would be greatly appreciated.
Diesel Freak, I assume you are knowledgeable of the CANBUS protocols. You must send a Remote Data Request. By sending a REMOTE FRAME to a node requiring data and may request another node to send the corresponding DATA FRAME. The DATA FRAME and the corresponding REMOTE FRAME are named by the IDENTIFIER.
Several years ago I got a copy of the CANBUS specifications with the idea that I could reprogram the ECM. The problem is identifying the nodes used by Cummins and understanding their coding. That info is proprietary and is not found anywhere.
DF,
I think youre right. the bus should be live with data all the time.
If you're just listening you should be able to basically put a sniffer on the bus to monitor the traffic.
Try reaching Marco. He might be able to shed some light here.
I would bet you are hearing what you want to hear... all the parameter you are trying to watch have to be transmitted periodicallly they would appear to be a repeating pattern with very minor deviation.
You'd have to be missing something.
I'm glad to see you got this far. I know a lot about software but I wouldn't know where to start on hardware.
Gimme a yell maybe we'll both learn something.
Later,
Mark
being transmitted out of the CANBus plug on a 2000 Dodge. I have a prototype board consisting of a Microchip PIC, a MCP2510, and a PCA 82C251.
Did you get this to talk to the bus? I"m looking to build a module that will sit on the CCD bus and respond to queries from the PCM directed to the ABS, and the AirBag controllers, that would respond with the "I'm Here/OK response" the PCM wants to see... . ( I removed them from the circuit on a conversion I'm installing) and I know that the PCM is going to throw codes every time it tries to poll them!
only one message repeatedly with an ID that is NOT defined in the 1939 standard (HS-1939). Is this port really using 1939? Has anyone
Do you by chance know the address's of the ABS and ABM modual's
Thanks
William.....
