Engine/Transmission (1998.5 - 2002) edeg ez stacking
2nd Gen Non-Engine/Transmission Loud Clunk with Full Left Turn
Engine/Transmission (1994 - 1998) exhaust manifold bolts
They work good together. I would put the EZ into the MAP sensor first and then put ours after that. Of course it depends on where the EZ actually caps the boost levels and you might not get the full fueling affect of the Xzillaraider. IF you think you loose fueling on the upper end then switch them.
