Those of you that have this, what do they show you and what do they not show that you would want to see? Meaning what extra gauges would you need/want? Also would it be safe to run this with an existing chip?
What do you mean by "unplug the gauge every time you want to change your tune"? On mine you just hit the arrow buttons to change the tune to a higher or lower setting. Am I missing something?
The budget woulnt really allow the Juice at least not yet, hence asking if it was safe to run with the existing chip. Eventually yes I'd get the Juice. It sounds like egt and fuel psi are the more important #'s to keep track of? Also sounds like the Attitude does not read fuel psi on the 3rd gen. I understood the Attitude to be on the fly adjustable? Am I mistaken? Boost is the psi of air entering the turbo? If your not drag racing is this something you need to see? I drove an 06 F-350 with a factory boost gauge but dont remember there being an egt.
Thanks thats the info I was looking for. One more question, Who makes white faced black numbered gauges that MOST resemble the stock in dash gauges? Would like to keep the same visual effect through out the truck.
