After running the EZ on 3 for a few weeks and looking at 1350* (and backing out), I just installed the supplied boost elbow - was able to pull off the stock hose with factory clamp still on and install the EZ elbow. Should still be able to put the stocker back in using the factory clamp.
EGT temps went down quite a bit - Boost now reads about 33psi and I can just barely hit 1200* but it rises much slower now. Seems to cool down quicker as well. Anyone running an EZ without EGT guage might want to put the elbow in.
I swapped mine from under the truck without touching any stuff up top. Just reached up with a pliers and twisted the hose off at the clamp. Took about 10min.
