SnoKing
"Power Level 1 on the Comp is the same as the EZ; on Power Levels 2-5 additional power is added via the wire tap onto the injection pump. If the pump wire is not attached with a Comp, Levels 2-5 are still operational, but the power gain is not any higher than Level 1. Under this scenario, however, power will come on much earlier in the throttle. "
OK, can someone please explain to one with a thick head. So the sublevels do not do anything in the if the injector wire is not hooked up, and level 2-5 cause earlier fueling? Someone please help me understand. SNOKING
