Edge Comp settings
5" Exhaust Questions
Short Shifter Warning!!!
Can anyone tell me how to set the sublevels for smoke on a Edge Comp I lost the instructions a long time ago and got a new one due to the original breaking
thx in advance
I never had instructions either, but I think somebody linked me to the install/op directions on here.
Sublevels are accessed by holding the "on" button down for a couple of seconds. If you hold it down too long or short it'll simply turn off. So fiddle with it until the "level" LED's flash, then you're in sub-mode. Set your sublevel and hit "on" switch again-Comp will go off, then hit it again and you're back in the smoke.
Confused yet?:confused:
And you can set a sub level for each of the 5 power levels by holding the "on" button while in a particular power setting.
Craig
