Engine/Transmission (1998.5 - 2002) Edge comp w/ injectors?
2nd Gen Non-Engine/Transmission Front blinker lens
2nd Gen Non-Engine/Transmission dual exhaust anyone???
I have a Edge comp box on my 99 3500 and I already have 90 hp injector nozzels but I am thinking about upgrading to bigger injectors does anyone have any suggestions on what I should go with??
any advise is gratley valued.
Welcome to the TDR
What's your goal? You already have 90hp injectors, do you tow? race? Do you have a bigger turbo? Gauges? Take a minute to fill out your signature so everyone can see what kind of setup you have. It makes it a lot easier to give advice. I would recommend mach 4's based on everyone's reviews for a good all around injector (150hp) that is a step up from what you have but depending on your setup and the direction you want to go that may not be the best recommendation.
I am prejudiced toward Formula 1 injectors..... As mentioned by DHadyden knowing what mods you have done to your truck along with what you want to do with it works into the equation.
Doug
Another vote for Formula 1 (even though I don't have them, I will be getting them... eventually). As far as more power, determine what you want to do with the truck as said and watch the airflow side of the equation. Without a turbo upgrade, some of the newfound power may be unusable if you go really big.
I finally figured the signature out hopfully.
I use the truck for fun and occational pulling. I want more black smoke so I figured injectors would be the answer.
Stage 3s
I have the drag comp with Bully Dog 3 (100hp) injectors and they will pull 14 thousand pounds to Reno without dropping below 60 :D (well I take that back CHP seems to follow me up Hwy 80 :-laf ) I have thought about going bigger but need a turbo first.
I thought once about stacking two boxes togather instead of injectors but i am having second thoughts. I know somone who stack 2 bully dog boxes togather and he sed it was very impresive. but in a way I think I would rather have the natural power and smoke of the injectors. >:)
Ahhhhhhhhhh welcome to the site, you will learn very quickily, what you want, and what it will take to get there. The guys on here are great. Don't be so eager to buy right away, do the research and take time to fit what you are looking for, not what someone else says is good, because we all have an opinion, in the long run it can save you a lot of money. Later Jim.
