Darn Marcel, I never realized how close Addison was, if you think the Comp made things hop, you should see what a set of DD II's will do for it, of course then the EGT's will really be out of range. When I had just the Comp, with a 4 inch exhaust and BHAF I could see 38 psi of boost but EGT's never really climbed much past 1300, I usually let out of it around there, I think I would've had to try pretty hard to hit 1500 empty. Now with the DD II's it'll peg my pyro really quick. Surprisingly the EGT's aren't too bad going down the pulling track until the last little bit. Recently I made a pull and went 265 feet or so, at around the 240-250 mark I was at 1400 and it was climbing at the very end but not quite pegged.
