Edge EZ and reflashed ECM
anyone need a roll top bed cover
I currently have the TST-reflashed ECM (it was reflashed by Mark Chapple before Cummins shut him down) and was wondering if I would see any power increase by installing an Edge EZ? My understanding is that the Edge EZ and the TST-reflashed ECM basically have the same parameters as the ECM found in Cummins RV's.
Would I need to go with the Edge Comp or PM3 to get more power?
Any help would be appreciated.
This board RULES!
Does the TST reflash affect the timing ??? If so, I'd hazard a guess that the TST PM would be a better add on rather than the Edge EZ or Edge Comp, as both of the Edge boxes affect the timing. Best bet would be to speak with Mark directly.
Scott W.
If you want more power get rid of the enemic 275's, put in some 2's and let the MC ECM do its thing. They will probably lower egt's too. :cool:
The best advice would be to do like big saint said, talk to Mark at TST, he is only a phone call away and would be the best person to ask.
Ron
with a reflashed ECM you want old school fueling increases , a PM , an original power edge , one of the hot versions , or a 3 wire blue box , add a set of DD2 or DD3 injectors and ROCK n' ROLL ...
of course then you may need a new clutch
Thanks alot fellas. I just called TST and they said the their PowerMax fueling boxes would add the extra power on top of the reflashed ECM power. Now after I burn my bonus money on a PowerMax and DDII's, I will *need* that South Bend Clutch (and another bonus)
Thanks again and as usual this board rules
