Edge EZ intall??
Exhaust Blanket/ Thermal Wraps
daddys new babby
CumminsAholic
I just recieved a used edge ez. I know that the 2 plugs hook up into the map sensor, but there's another plug in with 2 wires, a light and dark blue. It's only the female end, no other half. Which is ground and which is positive? I didn't get any instructions, so I don't have a clue. TIA
Corey
Hey, I have an EZ on a '98. 5. MY directions say that the triangle shaped connector is located down by the power steering pump. Thats one done. Unpug the map senser, plug the EZ into it, then plug the truck wires into the EZ. All done but the boost elbow.
I can't download them, it comes up as "404 file not found". Thanks WyoJim, I'll bring it in the shop and look for the connector. I thought that maybe I had to splice into them wires, but I guess not. Easier than I thought.
Corey
Your Datalink plug(triangle one) is probably going to have a cap on it. Remove it and just plug the EZ in. You can't miss it, it's right were the VP44 is.
Thanks Guys, I found it. It did have a cap on it, dangling right under the vp44. It's on and working, just have to get some velcro tomorrow. Makes a difference, just in a 5 min test I can tell it complients my "major fueling" box pretty good. It lowered my WOT egt's, but I'll have to drive it more tomorrow to see how much. It's dark and snowing here now, I broke the tires loose at 60 :D, and I don't want to go into the trees testing. :eek:
Thanks Again for the quick replies.
Corey
