edge ez question
Dodge Transmission Filter
600 exhaust mods - results
I just received my edge ez after many hours of research into posts here and am going to try it for awhile and maybe update to a cab switchable box if it does not satisfy. I read the instructions and have not installed it yet as I am still waiting for my guage package to come in from Genos.
Question: In the instructions it says that it is set at level 3 from the factory and they show this setting should be X:: :X:
When I opened the box it is set as follows :X: :X:
Should I move the left setting back one space as the directions say or should I leave it alone? Does it matter where the left side settings are located as it appears in the directions that it does not?
In the directions it says that the levels are set by moving the right side and leaving the left in the first position as indicated by the pic in the directions: X:: which is not how mine was new in the box as it was :X:
By the way, the forth pin on the left side lower is cut off as I have heard the later versions have come so you cannot access the 5 and 6 settings, however all pins are available on the right side. My box shows a manufacture date of 4/04.
CTDCAL.
All the plugs on the left side are just dummy's. They don't do anything other than hold the jumpers in place. The right side is where the action is. You will be fine...
have fun with your box, they are a blast... . :rolleyes: Those poor back tires :rolleyes:
Good luck
Dave
