EDGE EZ settings, help identifing injectors
270 HP Programmer!!!
5w-30 or not?
Hello,
I am a new user to this board as well as being a new Dodge owner. I recently purchased a 2003 Dodge RAM 3500 Dually with some work done to it. I knew going into the purchase that it had an Edge EZ, exhaust, and Exhaust brake. I was surprised to find out on the drive home the trubo reaching 35psi of boost. Upon inspection of the jumper settings of the Edge EZ I found the Jumper to be on the "unmarked" jumper. I was hoping somone could shed some light on this.
A friend, and TDR boardmember, drove my truck today and suspected the injectors have been changed out. Since I am new to this I am also wondering how I go about identifing what work has been done.
Thanks for all of your help, I have attached a picture of the EZ box and the jumper setting.
J. J. Pudenz
EZ settings:
Level 1 XX: :::
level 2 X:: ::X
level 3 X:: :X:
Level 4 ::: :XX
Secret level
Level 5 ::: X::
Older boxes
Level 6 ::: XX:
Level 6 is boost fooler only on the newer boxes, or so I have been told.
What is setting 5
Setting five as shown in the above post is where thre jumper sits. What is this settings specifications?
Thanks
JJ
Thanks
JJ
Don't know the exact specs on this setting, but I do know I would not be set above 4 till I knew what is done to the truck, as I don't care to blow the relief valve on the rail. Track down the previous owner and get some answers. If you want more power than level 4, get a PMCR.
