Details here: TDR Privileges
Hello to all! This is my first post and soon to be first upgrade (mod). I bought a used edge ez and didn't get a manuel with it so figured I would post and ask for a little help. My truck is a 99. Any help would be greatly appreciated, thanks. Brad
The EZ plugs into the MAP sensor, which is located behind the fuel filter. Simply un-plug the MAP sensor connector, plug in the EZ, then plug in the MAP sensor connector into the remaining female connector on the EZ harness. The instructions say to disconnect the batteries before hand, thats up to you.
I also have 99 and just installed ez the other plug is next to the front left side of the injection pump on drivers side. This has a small triangle plug on it remove and save cap them plug in the other plug to this . If you can't find it look between battery and injection pump down low.
For those of you who are running with the EZ, have you noticed any increase or difference in your fuel mileage? That is assuming that you are still using the same driving habits.
