Edge EZ
Mach 2's are in !!!
music wire for o-rings
i just installed an EZ in my 99, and man what a difference:eek: i can see how someone could spend big $$ BOMBing their truck. i also just purchased a set of gauges but havent installed them yet:(
i am planning a K&N FIPK next and that will probably be about it for awhile then maybe an exhaust, or maybe i should do the ex. before the K&N???
what do y'all suggest????
TIA:D
I suggest you skip the K&N and get something that will protect your engine. It's been proven that the K&N doesn't filter as well as it should. Search around and you will find better alternatives on here. AFE for one. Just my . 02 Russ
B. H. A. F Cummins part # AH 19037, if you want get an outerwears cover for it to keep out the little stuff 1-800-967-3450 and while you're at it let the silencer ring escape. Mine wound up on the back of a milk carton.
