Edge Ez ?
TOWloc--Pressureloc--Smart controler--Emjay???
reprogram speedo
I have an 04 with the 305/555 and I'm running the Edge EZ with a drop in airaid air filter and by next week I should have my Bank's 4" exhaust installed. My qustion is that with just the airaid air filter and the exhaust what power level should I run my EZ at w/o gauges and what is the highest power level I should run when towing? :confused:
Thanks in advance
I would not run the EZ on ANY setting without gauges. $200 is cheap insurance. Even pay someone to install them if you have to.
Blake
I have hit 1350 deg empty going up a small grade with my edge on level 4. Gauges are a lot cheaper then a turbo or worse an engine. Buy the gauges. John.
Get gauges!!. Without gauges I towed about 2000lbs without gauges and man o man I shouldn't have done that come to find out. I didn't realize how fast things heat up until I saw it for my self with the gauges. I tow on level 4 and use my foot to keep the temps down.
