edge hot juice
Practical Solutions?
Whats needed with EX. brake?
My box seems to set off the check engine light and various engine codes. There is nothing ever wrong with the vehicle. If I take the box off and reset the codes, then reinstall the box the check engine light will come back on and start throwing erroneous codes again.
Is this normal and is there a way to fix it? How can I reset the computer withought having to hook it up to an expensive machine all the time?
To see what codes you have, cycle the key 3 times and look at the odometer and write the codes down. Then call Edge and they will probably send you a new updated Version 2 Juice module. I had to do it on my truck and have had no codes since. You will probably get the injector circuit codes, the Juice module looses the signal now and again. No big deal, just drive the truck normally.
Give me a call if you need a hand
JC
It is not normal, I ran the standard and HOT Juice/Attitude for months. Stacked an EZ and ran the truck hard. Uninstalled and reinstalled number of times. I never had any codes at all. I would ask for a different Juice/Attitude with new wiring harness.
