DonRam240
I'm planning to add the monitoring-only CTS3 to our 2018 Ram 3500HD pickup, and include the Turbo Timer. I thought from reading about it that this required adding the Turbo Timer accessory, and installing a sensor in the exhaust manifold, using a Basic Starter Kit to daisy chain the input to the CTS3. Mach 1 Motorsports in Hillsboro, Oregon is the place recommended to me by our dealer for this work. I was positively impressed visiting them to plan this yesterday. Their chief mechanic researched it, and he thinks the CTS3 has the Turbo Timer internally and could use one of the EGT feeds from the OBDII port to operate. That would mean nothing extra to buy at all. He had a hard time getting a complete, solid-sounding answer from the rep on the phone; remember this is now a tiny division of Holley, so we weren't talking to an Edge expert.
Can someone say, does the CTS3 have its own internal Turbo Timer that can use a factory EGT feed, from the sensor closest to the exhaust manifold? I understand that under load, at operating engine speed, the closest sensor can see a temp that is 20-30 deg F lower than the manifold exhaust temp, and that's why a manifold sensor is recommended for this function. If the basic idea works, and the set point for the Turbo Timer is adjustable as the mechanic understands things to be, could I use this method and just set the shutdown temp 30 degrees lower than the design setting so I can't mess it up with a quick stop on the road, forgetting to let her idle for 3-4 minutes?
