Engine/Transmission (1998.5 - 2002) Edge Jucie installation question
2nd Gen Non-Engine/Transmission PSC box and Borgeson shaft?
Engine/Transmission (1998.5 - 2002) click,tick, ting sound
I am currently installing Juice w/Attitude in a 98. 5.
Is the wire going to a spare fuse in the engine compartment fusebox the wire that powers the Juice box, and the wire going to a fuse in the dash-fusebox what keeps the engine running when using the 'turbo timer'?
There is one short and one long wire, so it is obvious which goes where, but I think the installation instruction is somewhat unclear on this.
Yes the short one will controle the power to the "BOX" the long one controles the turbo timer! if the wire come off the fuse (in the engine) you will notice that you can pull the turbo timer off its power and the motor will shut off!
Thanks CarneyJ,
Just downloaded the installation manual from Edge's website. Now they have switched the designation of the power cable and turbo timer cable in the diagram, but IMHO it is still wrong. Have sent a mail to Edge.
No big deal since the cables are different length and only fit one way, but the manual should be correct in the first place.
Very true! i remember this problem but like you i was able to figure it out if you have any Q's just let me know! have fun and hold on! ps dont forget to get the free hot code by being a member of TDR!
WHAT??? You can get the HOT up-grade FREE??????
ya Tell them you are a member of TDR and they will get you to download a waiver form and you fax it to them then they will give you the code!
