I have been paying more attention to the Attitude's configuration abilities. Most importanly the Backdown feature. My un-official findings are that, with MAX Boost set to 36psi, Max EGT set to 1300, I "feel" more responce and longer hard pulls with the back down's "On". Yesterday I seen 70%. This could all be in my head tho too. Becuase when I intentionally turn the backdowns off, I'm mentaly ready for speed, were as other times, it's more a reaction to traffic and I wasn't ready for the hard pull in 5th from 50mph and before I know it's approaching 100mph
This is also turbo + fuel theory as well. I suppose I should turn on my Intake temp display to varifiy these temp numbers. I'm look for tested experience here with in my trucks means.
Stock turbo. Stock injectors. I'm just running Hot Juice with straight pipe. . At WOT, at any settings thus far my exhuast color is rather grey/brown. It's not locomotive coal like some of you 2nd gen folks here. I can get this level of black smoke durning low boost only and clears right up at 12+ PSI. I'm assuming I have sufficient air to burn the fuel the edge chip is providing.
Here's the deal if I have the edge limit boost to 36psi, I will see no more then 37psi on the display, at this point, the chip is defueling to limit boost. EGT are about 1100-ish, all the way up to 100mph. .
If I run with back downs off, I'll see 40psi, maybe 41, EGT might tag 1200-1250. but she feels slower.
Question here, the turbo should be creating more hot air at 40psi (full fueling vs. 36psi (with less fueling). Is this difference in air temp going to dramaticly decrease HP that much? I wish I had numbers!!!!! I may get these numbers at lunch and go for a drive.
Anyone get some techincal details on this with their own trucks yet?
Friend lives in the middle of no where and I may do some 0-60 runs with the edge monitoring times with differnet settings at his place. Is that 1/8mile tracks open still in MN this time of year?
