I got my dad the Edge Juice W/A for Christmas. Installed it and everything ran great, until we played with 5x5. On the second hard acceleration the truck started to miss and engine light came on. Fault code was for cyl. 3&6. I did another hard launch and the truck stalled, fault codes for cyl. 2&4 and 3&6 logged. Tried playing with the low boost fueling on E5, it helped very little.
Called Edge and they sent another box. Installed just the box and as soon as the engine started the engine had a miss (cyl. 3&6 code) no matter what level. I checked all connections again and restarted engine, still missing and faults. Called Edge and they sent another box. Installed it last night and it ran great after test driving. Gave it back to my dad and 15min. later the problems back. Played with the truck tonight and the problem seemed to get worse and work its way down to level 3. If you started on level 2 and changed to level 5 on the fly it did not have a problem. The problem is intermittent. When the box is working it works great. The truck is a 04 Dodge 3500 2xi4 235 H. P CA. I'm told by Edge that they are not having this kind of problem with the early 3rd. gens. Im always the first guy to have the problems. Maybe they are right and we have a knack for picking the wrong truck at the right time. I have installed E. J. wA. on 4 other trucks (04. 5+) with no problems.
I'm in no way out to bash Edge. Just want to know if I should recal. the truck or go for the 4th. Edge box.
