edge juice w/attitude
post count
Can not send PM's?
I have a 2001 quad cab 5. 9 six speed w 116,000 miles and I just installed S&B air intake, MBRP 4" exhaust, and an edge juice w/attitude. Must say this truck is now an animal. Not really looking to burn up the track but nice to have the power. Put the system on to gain fuel economy while towing. Does anyone have experience with edge juice settings? I know all results are going to vary, I'm just looking for some similar results.
I installed my attuitue in march and love it! I have all my low bost fueling levels set on 2 except #5 and it's on 5 for a fun "smoke show" now and then. when driving empty I seem to get the best mileage on setting 4, usually around 18-20 if I can keep my foot out of it. In August I bought a '34 9000# camper in Michigan and towed it home to Nebraska and got around 14 average doing 65 the whole way on #2. (not to bad for a 208K mile truck). The higher settings may produce better mileage but I havent tryed very long because I dont like putting that much power to my 5 sp on those harder pulling hills. My jammer 3's add a lot of fuel on those higher settings. You may have better luck with stock injectors and the more duriable 6 sp. Hope this helps, just make sure you set all your alarms and turbo timer. I think they are the best part of the attuitude system. The fuel preasure alarm has saved my vp44 more than once from a dead lift pump. Have fun with it!
Thanks for the info, I found I had a weak pump the minute I started the truck after the install was complete. Replaced the lift pump right away. What do you have your boost alarm set at?
I need to be carefull with my boost for now because my wastgate is stuck shut and I can hit 35-38psi in a heartbeat if I punch it but I set my boost @32, Egt @ 1250, Turbo cool down @ 350, Engine temp @ 210, Fuel psi @ 5, Trany temp @ 230. FYI, I have a friend w/ a 06 who bought the hot unlock code and said that it's just to much and he would not do it again. The gains are incrediable but I know I would just distroy my truck with that. I went ahead and taped the pump wire but that is as far as I took it.
