Edge Juise w/ Att.?
Trans temp probe keeps failing
edge HOT
Well I had to send off my Edge Juice and Monitor. The truck lost power and the monitor went out. unhooked everything and truck ran fine.
I got the new one in today and done the install. Egt's will still not go over 900* (post turbo). My analog gauge would read 1200* on acceleration with my loaded trailer every time. Thermocoupler is in the same hole.
Now the boost level on the monitor with the box on "0" reads up to 39 while on my other monitor it would read no higher than 30+-. My buddies is doing the same thing. He went to the dealer and showed normal boost pressures on their equipment. How am I supposed to get a true reading with results like this.
Whats up with this piece of Junk?
Anybody else with this problem?
does your monitor momentarily switch back to zero every once in a while? mine does about the same thing, but my egts will not go over 1150. hell i got beat by a stock duramax the other day , and that aint cool... that is why i am sending it all back and gatting the HOT version . and see if maybe it is the box...
