Edge timing advance box
What does ETH/DEE mean??
massive connecting rod
Who has the new edge timing advance box that adds fuel also? Who is selling them and who sells them the cheapest? I would like to hear some fist hand likes/dont likes about it.
I have a hot PE and love it. How does an Edge timing box work with a PE?
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member. http://www.geocities.com/chadsheets
Chad,
The EZ advances timing and adds fuel. It does work with the PE.
Where did you get your Hot PE? You should be able to get the EZ there at a discount because you already bought the Power Edge. If not call Brett or Taylor at Edge Products.
Hope this helps, Big Bob.
[This message has been edited by BIG BOB (edited 01-16-2001). ]
I drove with both the Edge (hot) Power Edge and the Edge EZ in Bill Kondolay's Ram last Saturday. Awesome power output! He also had Bosch 275 HP RV injectors installed as well. If I remember correctly Bill has his EZ setup at the factory settings (most aggressive).
DTT is an Edge dealer... give him a call for more information and pricing.
<font color=blue>Chad -
Call the fellas at Edge (either Brett or Taylor) and talk to them about it. It will be $450 for a full version of the EZ This is a discounted price because you already own the PowerEdge. It will have a different harness then what comes on a regular EZ, you'll plug in the PE, then the EZ, then the map sensor. You might want to wait until they release their Edge Comp box, which will be both boxes combined into one. I don't know when the release date is.
It works fine together. #ad
Edit : Edge decided not to produce timing only Box. See below post for solution<font size=-2>
[This message has been edited by KatDiesel (edited 01-18-2001). ]
kat , timing only version ??? thats an interesting note , i assumed that the fueling had to be increased along with the timing ala VA ? not true , sounds like it would be very FRIENDLY with my HOT PE , especially with a set of bigger injectors .
<font color=blue>This information is about a month old, I inquired about it for another member. So they may have decided to not produce it anymore? I'll give Brett a call tommorrow morning and see what I can dig up on it. But last I heard it was available.
<font color=blue>Well after talking with Brett there is no "Timing only" box. However the EZ produced for DD is timing only on Level I. Thats the only way to get the "Timing only". The other levels also add fuel like an Regular EZ.
Sorry for the confusion, my info was a bit outdated.
I'll give them a call to see about the $450 price since I have their PE. If thats the deal then I might be able to talk myself back into needing one.
