Edge users mileage?
Best price on Smarty JR ??
Edge W/Attitude Blues
Smokieokie
Hi,ya'll. I'm thinking about stacking an EZ with my Hot Juice w/Att and I'm wondering what kind of mileage increase I could expect out of an '04. 5 2500 QC 4X4 SB NV5600 3. 73s Afe cold air intake Magnaflow muffler stock tires? I have been getting a little better than stock with the Juice set on level 3, but I've been wondering if more rail pressure would help out any. I'm still running the stock clutch, so I dont need any more power necessarily, but I'm wondering if-driven in moderation-an EZ would help my mileage? Thanks for the input.
I was thinking about this. I even have the EZ sitting on the shelf. I called EDGE and they did not recommend it. They said that the high pressure of the EZ with the J/A could cause serious damage to the injector pump. They also said that it would not increase my HP very much. Based on this and the previous articles in the TDR stating that stock injector pumps and lift pumps can't supply enough fuel on the J/A setting 5 for more than a dyno pull. After that you are really running setting 4. I am getting rid of the EZ and just sticking with the J/A.
If you guys do and get something out of it let me know, it would not be the first time I made a mistake.
OK, somebody explain this to me. Edge doesnt recommend stacking these two boxes, but the Smarty Srs use both timing and rail pressure increases in one package. Is the difference that Edge uses duration also and Smarty doesnt, or what? What Does the "torque management" setting do on the Smarty S-04 or S-06?
I have had the EZ for quite a while and saw +1. 5 MPG, hand calculated. Currently running the Smarty JR on level 4... not too surprising but not seeing any milage improvement... am seeing more power! Can I stack the EZ with the Smarty JR?
