Details here: TDR Privileges
I was wondering what the owners of the Edge/wam where running on there display. I am using the 4 display, reading boost, pyro, baro pres and intake temp. I'm just curious what others are using.
The bar graph is as close to a quick read that analog gauges give ya.
Water, the stock one does well.
Trans slip? ConFE makes the tires slip first.
I've been running the intake temp on a 3 display setup since I've never used a cold winter front cover yet. Curious as to what the temp will be vs out side temps with different configs on the flaps and what not.
One could typically assuming under empty loads that your intake temps are 10-14 degrees above ambient with out a cover with stock inner cooler
